Process Data Mapping (JSON)
Submits a request to initiate a new Data Mapping operation.
Request takes a JSON Identifier (for Data Mapping) as content, and on success returns a response containing additional headers that specify the ID of the new operation as well as link URLs that can be used to retrieve further information/cancel the operation.
Request
Method Type:
POST
URI:
/rest/serverengine/workflow/datamining/{configId}
Content: JSON Identifier (for Data Mapping)
Content Type:
application/json
Add. Headers:
Parameters
Path
configId
Managed File ID (or Name) of the Data Mapping configuration in File Store
Query
validate
false
Only validate the Data Mapping operation to check for mapping errors
Response
Success
202
Accepted
  • operationId – Operation ID of new Data Mapping operation
Error
400
Bad Request
application/json
Data file or Data Mapping Configuration not found in File Store
401 Unauthorized
application/json
Response when either:
403 Forbidden
application/json
500
Internal Server Error
application/json
JSON Identifier bad or missing
