Process Data Mapping (PDF/VT to Data Set)
Submits a request to initiate a new Data Mapping operation using a PDF/VT data file specifically.
No Data Mapping configuration is specified, and a Data Set will be created based on the default properties extracted from the metadata of the PDF/VT data file.
Request takes no content, and on success returns a response containing additional headers that specify the ID of the new operation as well as link URLs that can be used to retrieve further information/cancel the operation.
Request
Method Type:
POST
URI:
/rest/serverengine/workflow/datamining/pdfvtds/{dataFileId}
Content:
Content Type:
Add. Headers:
Parameters
Path
dataFileId
The Managed File ID (or Name) of the PDF/VT data file in File Store
Response
Success
202
Accepted
  • operationId – Operation ID of new Data Mapping operation
Error
400
Bad Request
application/json
PDF/VT data file not found in File Store
401 Unauthorized
application/json
Response when either:
403 Forbidden
application/json
