Add Data Records
Submits a request to add one or more Data Record entities to one or more entities in the Server as either:
  • a Data Record of an existing Data Set entity in the Server, or
  • a nested Data Record in a Data Table of an existing Data Record entity in the Server
Request takes JSON New Record Lists as content (each with the Data Set/Data Record ID, Data Table and the new records/values), and on success returns a response containing no content.
Request
Method Type:
POST
URI:
/rest/serverengine/entity/datarecords
Content: JSON New Record Lists of the new Data Records
Content Type:
application/json
Add. Headers:
Response
Success
200
OK
Data Records for Data Set/Data Record entities successfully added
Error
401 Unauthorized
application/json
Response when either:
403 Forbidden
application/json
500
Internal Server Error
application/json
JSON New Record Lists invalid or missing required structure
