Get Data Record Properties
Returns a list of the properties for a specific Data Record entity.
Request takes no content, and on success returns a response containing a JSON Name/Value List (Properties Only) of all the properties for the Data Record.
Request
Method Type: |
GET |
URI: |
/rest/serverengine/entity/datarecords/{dataRecordId}/properties |
Content: | – |
Content Type: |
Add. Headers: |
Parameters
Path
dataRecordId |
The ID of the Data Record entity in Server |
Response
Success
200 OK |
JSON Name/Value List (Properties Only) of properties for Data Record | application/json | – | Data Record entity properties successfully retrieved |
Error
401 Unauthorized |
application/json |
403 Forbidden |
application/json |
