Get Data Record Values
Returns a list of the values for a specific Data Record entity, and potentially the values of any nested Data Records (if recursive).
Request takes no content, and on success returns a response containing either:
- JSON Record Content List of all the values for the Data Record
- JSON Record Content List (Explicit Types) of all the values and data types for the Data Record
- JSON Record Content List (simplified) of all the values for the Data Record
Request
Method Type: |
GET |
URI: | |
Content: | – |
Content Type: |
Add. Headers: |
Parameters
Path
dataRecordId |
ID of the Data Record entity in Server |
Query
recursive |
False |
Recurse all Data Tables within the Data Record and retrieve the values of any nested Data Records |
explicitTypes |
False |
Deprecated Retrieve both values and data types of the Data Record |
outputFormat |
default |
The output format of the data (either |
Note: Query parameters are case-sensitive.
Response
Success
200 OK |
JSON Record Content List of the values for Data Record | application/json | – | Data Record entity values successfully retrieved |
200 OK |
JSON Record Content List (Explicit Types) of the values and data types for Data Record | application/json | – | Data Record entity values and data types successfully retrieved |
Error
401 Unauthorized |
application/json |
403 Forbidden |
application/json |
500 |
application/json |
Server error or invalid Data Record ID specified |
