Get Multiple Data Record Values
Returns a list of the values for one or more Data Record entities, and potentially the values of any nested Data Records (if recursive).
Request takes no content, and on success returns a response containing either:
- JSON Record Content Lists of all the values for each Data Record.
- JSON Record Content Lists (Explicit Types) of all the values and data types for each Data Record
- JSON Record Content Lists (simplified) of all the values for each Data Record.
Request
Method Type: |
GET |
URI: | |
Content: | – |
Content Type: |
Add. Headers: |
Parameters
Query
id |
ID of each Data Record entity in Server |
recursive |
False |
Recurse all Data Tables within each Data Record and retrieve the values of any nested Data Records |
outputFormat |
default |
The output format of the data (either |
Note: Query parameters are case-sensitive.
Response
Success
200 OK |
JSON Record Content Lists of the values for each Data Record | application/json | – | Data Record entity values successfully retrieved |
Error
401 Unauthorized |
application/json |
403 Forbidden |
application/json |
500 |
application/json |
Server error or invalid Data Record ID specified |
