Get Multiple Data Record Values (JSON)
Returns a list of the values for one or more Data Record entities, and potentially the values of any nested Data Records (if recursive).
Request takes a JSON Data Record Identifier List (with Parameters) of the Data Record IDs as content, and on success returns a response, depending on the specified output format, containing either:
- JSON Record Content Lists of all the values for each Data Record (this is the default)
- JSON Record Content Lists (Explicit Types) of all the values and data types for each Data Record
- JSON Record Content Lists (simplified) of all the values for each Data Record
Request
Method Type: |
POST |
URI: | |
Content: | JSON Data Record Identifier List (with Parameters) specifying the Data Record entity IDs |
Content Type: |
application/json |
Add. Headers: |
Response
Success
200 OK |
JSON Record Content Lists of the values for each Data Record | application/json | – | Data Record entity values successfully retrieved |
200 OK |
JSON Record Content Lists (Explicit Types) of the values and data types for each Data Record | application/json | – | Data Record entity values and data types successfully retrieved |
200 OK |
JSON Record Content Lists (simplified) of the values for each Data Record | application/json | Data Record entity values successfully retrieved |
Error
401 Unauthorized |
application/json |
403 Forbidden |
application/json |
500 |
application/json |
Server error or invalid Data Record ID specified |
