Update Data Record Properties
Submits a request to update (and replace) the properties for a specific Data Record entity in the Server.
Request takes a JSON Name/Value List as content (the Data Record ID and the new properties), and on success returns a response containing the result of the request for update/replacement (“true”).
Request
Method Type: |
PUT |
URI: |
/rest/serverengine/entity/datarecords/{dataRecordId}/properties |
Content: | JSON Name/Value List of properties for Data Record |
Content Type: |
application/json |
Add. Headers: |
Parameters
Path
dataRecordId |
ID of the Data Record entity in Server |
Response
Success
200 OK |
Result of request to update Data Record | text/plain | – | Update of Data Record properties successfully requested (response of “true” for success) |
Error
401 Unauthorized |
application/json |
403 Forbidden |
application/json |
500 |
application/json |
Server error or Data Record ID mismatch in JSON |
