Update Multiple Data Record Values
Submits a request to update one or more values for one or more Data Record entities in the Server.
Request takes JSON Record Content Lists (Fields Only) as content (each with the Data Record ID and the new values), and on success returns a response containing no content.
Request
Method Type: |
PUT |
URI: | |
Content: | JSON Record Content Lists (Fields Only) of the values for the Data Records |
Content Type: |
application/json |
Add. Headers: |
Response
Success
200 OK |
– | – | – | Values of Data Record entities successfully updated |
Error
401 Unauthorized |
application/json |
403 Forbidden |
application/json |
