Delete Data Set Entity
Submits a request for a specific Data Set entity to be marked for deletion from the Server.
Request takes no content, and on success returns a response containing the result of the request for deletion (“true” or “false”).
Request
Method Type:
POST
URI:
/rest/serverengine/entity/datasets/{dataSetId}/delete
Content:
Content Type:
Add. Headers:
Parameters
Path
dataSetId
ID of the Data Set entity in Server
Response
Success
200
OK
Result of request for Data Set removal text/plain Deletion of Data Set successfully requested from Server (response of “true” for success or “false” for failure)
Error
401 Unauthorized
application/json
Response when either:
403 Forbidden
application/json
