Get Data Records for Data Set
Returns a list of all the Data Record entities contained within a specific Data Set entity.
Request takes no content, and on success returns a response containing a JSON Identifier List of all the Data Records in the Data Set.
Request
Method Type: |
GET |
URI: | |
Content: | – |
Content Type: |
Add. Headers: |
Parameters
Path
dataSetId |
ID of the Data Set entity in Server |
Response
Success
200 OK |
JSON Identifier List of all the Data Records in Data Set | application/json | – | Identifier List of Data Records returned |
Error
401 Unauthorized |
application/json |
403 Forbidden |
application/json |
