Update Data Set Properties
Submits a request to update (and replace) the properties for a specific Data Set entity in the Server.
Request takes a JSON Name/Value List as content (the Data Set ID and the new properties), and on success returns a response containing the result of the request for update/replacement (“true”).
Request
Method Type:
PUT
URI:
/rest/serverengine/entity/datasets/{dataSetId}/properties
Content: JSON Name/Value List of properties for Data Set
Content Type:
application/json
Add. Headers:
Parameters
Path
dataSetId
ID of the Data Set entity in Server
Response
Success
200
OK
Result of request to update Data Set text/plain Update of Data Set properties successfully requested (response of “true” for success)
Error
401 Unauthorized
application/json
Response when either:
403 Forbidden
application/json
500
Internal Server Error
application/json
Server error or Data Set ID mismatch in JSON
