Get Document Set Metadata Properties
Returns a list of the metadata properties for a specific Document Set entity.
Request takes no content, and on success returns a response containing a JSON Name/Value List (Properties Only) of all the metadata properties for the Document Set.
Request
Method Type:
GET
URI:
/rest/serverengine/entity/documentsets/{documentSetId}/metadata
Content:
Content Type:
Add. Headers:
Parameters
Path
documentSetId
The ID of the Document Set entity in Server
Response
Success
200
OK
JSON Name/Value List (Properties Only) of metadata properties for Document Set application/json Document Set entity metadata properties successfully retrieved
Error
401 Unauthorized
application/json
Response when either:
403 Forbidden
application/json
