Service Handshake
Queries the availability of the Document Set Entity service.
Request
Method Type:
GET
URI:
/rest/serverengine/entity/documentsets
Content:
Content Type:
Add. Headers:
Response
Success
200
OK
Handshake message:
Server Engine REST Service available: DocumentSetEntityRestService
text/plain REST Service available
Error
401 Unauthorized
application/json
Response when either:
