Find Data Entity
Submits data entity search criteria to the OL Connect Server.
Request takes a JSON Search Parameters structure as content and on success returns a response containing JSON Identifier Lists (with Sort Key) of the data entity IDs matching the search criteria.
Method Type: |
PUT |
URI: | |
Content: | JSON Search Parameters containing search criteria/rules |
Content Type: |
application/json |
Add. Headers: |
Response
Success
200 OK |
JSON Identifier Lists (with Sort Key) containing all the entities matching the search criteria | application/json | – | Search request successfully executed |
Error
401 Unauthorized |
application/json |
403 Forbidden |
application/json |
500 |
application/json |
Server error or Invalid JSON structure specified |
