Delete Managed File or Directory
Removes an existing file or directory of a specific Managed File ID (or Name) from the File Store.
Request takes no content, and on success returns a response containing the result of the request for removal.
Request
Method Type:
GET
URI:
/rest/serverengine/filestore/delete/{fileId}
Content:
Content Type:
Add. Headers:
Parameters
Path
fileId
The Managed File ID (or Name) of the file or directory in File Store
Response
Success
200
OK
Result of request for removal text/plain Removal of file or directory successfully requested from File Store
Error
400
Bad Request
application/json
Deletion failed / File still required by OL Connect
401 Unauthorized
application/json
Response when either:
403 Forbidden
application/json
404
Not Found
application/json
Invalid Managed File ID
500 Internal Server Error
application/json
Connection refused
