Download Managed File or Directory
Obtains an existing file or directory of a specific Managed File ID (or Name) from the File Store.
Request takes no content, and on success returns a response containing the file or directory data (as zipped file).
Request
Method Type: |
GET |
URI: | |
Content: | – |
Content Type: |
Add. Headers: |
Parameters
Path
fileId |
The Managed File ID (or Name) of the file or directory in File Store |
Response
Success
200 OK |
File |
application/octet-stream |
Content-Disposition – Filename of the Managed File Example: "attachment; filename=Promo-EN.OL-datamapper" OL-Original-Filename - The original file name, if available. E.g. "Default Print Settings.OL-jobpreset" |
File successfully downloaded from File Store. |
200 |
Directory (zipped) |
application/zip |
Content-Disposition – Filename of the Managed Directory Example: "attachment; filename=letter-ol.zip" OL-Original-Filename - The original file name, if available. E.g. "Letter.OL-template" |
Directory successfully downloaded from File Store. |
Error
401 Unauthorized |
application/json |
403 Forbidden |
application/json |
404 Not Found |
application/json |
