List Resources
Returns a list of one or more types of resources in the File Store: data files, templates, data mapping configurations, job creation presets and output creation presets, depending on the Type query parameter. If no Type value is passed, all OL Connect resources, but no generic or data files are listed.
This call only returns the list of resources that have been uploaded with the persistent attribute.
Examples:
/rest/serverengine/filestore/resources?type=TEMPLATE
/rest/serverengine/filestore/resources?type=TEMPLATE,DATA_MAPPING_CONFIG,JOB_CREATION_CONFIG
Request takes no content, and on success returns a response containing a JSON structure that has an array of objects holding base information on Connect resources.
Request
Method Type:
GET
URI:
Content:
Content Type:
Add. Headers:
Parameters
Path
type
If the type parameter is omitted the endpoint will return:
  • Templates
  • Data mapping configurations
  • Job Creation Presets
  • Output Creation Presets
The type or types (comma-separated) of the files to list. Possible values:
  • TEMPLATE: Templates
  • DATA_MAPPING_CONFIG: Data mapping configurations
  • JOB_CREATION_CONFIG: Job creation presets
  • OUTPUT_CREATION_CONFIG: Output creation presets
  • DATA_FILE: Data files
Response
Success
200
OK
A JSON structure that has an array of objects holding base information on Connect resources:
  • id (integer)
  • name (string)
  • path (string)
  • type (string)
  • size (integer)
application/json
List returned.
Error
401 Unauthorized
application/json
Response when either:
403 Forbidden
application/json
404 Not Found
application/json
  • No resources of the specified type found in File Store.
