Managed File or Directory Exists
Checks whether a file or directory of a specific Managed File ID (or Name) exists in the File Store.
Request
Method Type: |
HEAD |
URI: | |
Content: | – |
Content Type: |
Add. Headers: |
Parameters
Path
fileId |
The Managed File ID (or Name) of the file or directory in the File Store |
Response
Success
200 OK |
File or directory exists in the File Store. |
Error
401 Unauthorized |
application/json |
403 Forbidden |
application/json |
404 Not Found |
application/json |
