Process Job Creation Without Job Preset (By Content Set)
Submits a request to initiate a new Job Creation operation in which no Job Preset is used.
Request takes no content, and on success returns a response containing additional headers that specify the ID of the new operation as well as link URLs that can be used to retrieve further information/cancel the operation.
Request
Method Type: |
POST |
URI: |
/rest/serverengine/workflow/jobcreation/default/{contentSetId} |
Content: | – |
Content Type: |
Add. Headers: |
Parameters
Path Parameters
contentSetId |
A Content Set ID |
Response
Success
202 Accepted |
Error
401 Unauthorized |
application/json |
403 Forbidden |
application/json |
404 Not Found |
application/json |
Job Creation Preset or Content Set entity not found in File Store/Server |
