Process Job Creation Without Job Preset (By Content Set) (JSON)
Submits a request to initiate a new Job Creation operation in which no Job Preset is used.
Request takes a JSON Identifier List of Content Set IDs as content, and on success returns a response containing additional headers that specify the ID of the new operation as well as link URLs that can be used to retrieve further information/cancel the operation.
Request
Method Type: |
POST |
URI: | |
Content: | JSON Identifier List specifying a list of Content Set entity IDs |
Content Type: |
application/json |
Add. Headers: |
Response
Success
202 Accepted |
Error
401 Unauthorized |
application/json |
403 Forbidden |
application/json |
404 Not Found |
application/json |
Content Set entity not found in File Store/Server |
