Get Content Items for Job
Returns a list of all the Content Item entities (and their corresponding Data Record entities) contained within a specific Job entity.
Request takes no content, and on success returns a response containing a JSON Content Item Identifier List of all the Content Items for the Job.
Request
Method Type: |
GET |
URI: | |
Content: | – |
Content Type: |
Add. Headers: |
Parameters
Path
jobId |
The ID of the Job entity in Server |
Response
Success
200 OK |
JSON Content Item Identifier List of all the Content Items in Job | application/json | – | Content Item Identifier List returned |
Error
401 Unauthorized |
application/json |
403 Forbidden |
application/json |
