Get Job Properties
Returns a list of the properties for a specific Job entity.
Request takes no content, and on success returns a response containing a JSON Name/Value List (Properties Only) of all the properties for the Job.
Request
Method Type: |
GET |
URI: | |
Content: | – |
Content Type: |
Add. Headers: |
Parameters
Path
jobId |
The ID of the Job entity in Server |
Response
Success
200 OK |
JSON Name/Value List (Properties Only) of properties for Job | application/json | – | Job entity properties successfully retrieved |
Error
401 Unauthorized |
application/json |
403 Forbidden |
application/json |
