Get Job Segments for Job
Returns a list of all the Job Segment entities contained within a specific Job entity.
Request takes no content, and on success returns a response containing a JSON Identifier List of all the Job Segments in the Job.
Request
Method Type:
GET
URI:
/rest/serverengine/entity/jobs/{jobId}
Content:
Content Type:
Add. Headers:
Parameters
Path
jobId
The ID of the Job entity in Server
Response
Success
200
OK
JSON Identifier List of all the Job Segments in Job application/json Identifier List of Job Segments returned
Error
401 Unauthorized
application/json
Response when either:
403 Forbidden
application/json
