Update Job Metadata Properties
Submits a request to update (and replace) the metadata properties for a specific Job entity in the Server.
Request takes a JSON Name/Value List as content (the Job ID and the new metadata properties), and on success returns a response containing the result of the request for update/replacement (“true”).
Request
Method Type: |
PUT |
URI: | |
Content: | JSON Name/Value List of metadata properties for Job |
Content Type: |
application/json |
Add. Headers: |
Parameters
Path
jobId |
The ID of the Job entity in Server |
Response
Success
200 OK |
Result of request to update Job | text/plain | – | Update of Job metadata properties successfully requested (response of “true” for success) |
Error
401 Unauthorized |
application/json |
403 Forbidden |
application/json |
500 |
application/json |
Server error or Job ID mismatch in JSON |
