Update Multiple Job Properties
Submits a request to update one or more properties for one or more Job entities in the Server.
Request takes JSON Name/Value Lists as content (each with the Job ID and the new properties), and on success returns a response containing no content.
Request
Method Type:
PUT
URI:
/rest/serverengine/entity/jobs/properties
Content: JSON Name/Value List of the properties of the Jobs
Content Type:
application/json
Add. Headers:
Response
Success
200
OK
Properties of Job entities successfully updated
Error
401 Unauthorized
application/json
Response when either:
403 Forbidden
application/json
