Get Document Sets for Job Segment
Returns a list of all the Document Set entities contained within a specific Job Segment entity.
Request takes no content, and on success returns a response containing a JSON Identifier List of all the Document Sets in the Job Segment.
Request
Method Type:
GET
URI:
/rest/serverengine/entity/jobsegments/{jobSegmentId}
Content:
Content Type:
Add. Headers:
Parameters
Path
jobSegmentId
The ID of the Job Segment entity in Server
Response
Success
200
OK
JSON Identifier List of all the Document Sets in Job Segment application/json Identifier List of Document Sets returned
Error
401 Unauthorized
application/json
Response when either:
403 Forbidden
application/json
