Update Job Segment Metadata Properties
Submits a request to update (and replace) the metadata properties for a specific Job Segment entity in the Server.
Request takes a JSON Name/Value List as content (the Job Segment ID and the new metadata properties), and on success returns a response containing the result of the request for update/replacement (“true”).
Request
Method Type:
PUT
URI:
/rest/serverengine/entity/jobsegments/{jobSegmentId}/metadata
Content: JSON Name/Value List of metadata properties for Job Segment
Content Type:
application/json
Add. Headers:
Parameters
Path
jobSegmentId
The ID of the Job Segment entity in Server
Response
Success
200
OK
Result of request to update Job Segment text/plain Update of Job Segment metadata properties successfully requested (response of “true” for success)
Error
401 Unauthorized
application/json
Response when either:
403 Forbidden
application/json
500
Internal Server Error
application/json
Server error or Job Segment ID mismatch in JSON
