Delete Job Set Entity
Submits a request for a specific Job Set entity to be marked for deletion from the Server.
Request takes no content, and on success returns a response containing the result of the request for deletion (“true” or “false”).
Request
Method Type: |
POST |
URI: | |
Content: | – |
Content Type: |
Add. Headers: |
Parameters
Path
jobSetId |
The ID of the Job Set entity in Server |
Response
Success
200 OK |
Result of request for Job Set removal | text/plain | – | Deletion of Job Set successfully requested from Server (response of “true” for success or “false” for failure) |
Error
401 Unauthorized |
application/json |
403 Forbidden |
application/json |
