Get Jobs for Job Set
Returns a list of all the Job entities contained within a specific Job Set entity.
Request takes no content, and on success returns a response containing a JSON Identifier List of all the Jobs in the Job Set.
Request
Method Type:
GET
URI:
/rest/serverengine/entity/jobsets/{jobSetId}
Content:
Content Type:
Add. Headers:
Parameters
Path
jobSetId
The ID of the Job Set entity in Server
Response
Success
200
OK
JSON Identifier List of all the Jobs in Job Set application/json Identifier List of Jobs returned
Error
401 Unauthorized
application/json
Response when either:
403 Forbidden
application/json
