Get Result of Operation
Retrieves the final result of a completed Output Creation operation of a specific operation ID.
Request takes no content, and on success returns a response containing either the absolute paths of the final output files produced (multiple spool files) or the content of a final output file (single spool file).
Request
Method Type:
POST
URI:
/rest/serverengine/workflow/outputcreation/getResult/{operationId}
Content:
Content Type:
Add. Headers:
Parameters
Path
operationId
Operation ID of Output Creation operation
Response
Success
200
OK
Absolute Paths of the Output Files or the Output File itself
application/octet-stream Result of completed operation successfully retrieved
Error
401 Unauthorized
application/json
Response when either:
403 Forbidden
application/json
404 Not Found
application/json
Operation not found in Server
