Get Result of Operation (as Text)
Retrieves the final result of a completed Output Creation operation of a specific operation ID.
Request takes no content, and on success returns a response containing the absolute path or paths of the final output file or files produced (single or multiple spool files respectively).
Request
Method Type: |
POST |
URI: |
/rest/serverengine/workflow/outputcreation/getResultTxt/{operationId} |
Content: | – |
Content Type: |
Add. Headers: |
Parameters
Path
operationId |
Operation ID of Output Creation operation |
Response
Success
200 OK |
Absolute Path(s) of the Output File(s) |
text/plain | – | Result of completed operation successfully retrieved |
Error
401 Unauthorized |
application/json |
403 Forbidden |
application/json |
404 Not Found |
application/json |
Operation not found in Server |
