Process Output Creation (By Job) (JSON)
Submits a request to initiate a new Output Creation operation.
Request takes a JSON Identifier List (with Output Parameters) of the Job IDs as content, and on success returns a response containing additional headers that specify the ID of the new operation as well as link URLs that can be used to retrieve further information/cancel the operation.
Request
Method Type:
POST
URI:
/rest/serverengine/workflow/outputcreation/{configId}/jobs
Content: JSON Identifier List (with Output Parameters) specifying the Job entity IDs
Content Type:
application/json
Add. Headers:
Parameters
Path
configId
The Managed File ID (or Name) of the Output Creation Preset in File Store
Response
Success
202
Accepted
  • operationId – Operation ID of new Output Creation operation
Error
401 Unauthorized
application/json
Response when either:
403 Forbidden
application/json
404 Not Found
application/json
Output Creation Preset or Job entity not found in File Store/Server
500
Internal Server Error
application/json
JSON Identifier List invalid or missing required structure
