Process Output Creation (By Job Set)
Submits a request to initiate a new Output Creation operation.
Request takes no content, and on success returns a response containing additional headers that specify the ID of the new operation as well as link URLs that can be used to retrieve further information/cancel the operation.
Request
Method Type:
POST
URI:
/rest/serverengine/workflow/outputcreation/{configId}/{jobSetId}
Content:
Content Type:
Add. Headers:
Parameters
Path
configId
The Managed File ID (or Name) of the Output Creation Preset in File Store
jobSetId
The ID of the Job Set entity in Server
Response
Success
202
Accepted
  • operationId – Operation ID of new Output Creation operation
Error
401 Unauthorized
application/json
Response when either:
403 Forbidden
application/json
404 Not Found
application/json
Output Creation Preset or Job Set entity not found in File Store/Server
