Process Output Creation (By Job Set) (JSON)
Submits a request to initiate a new Output Creation operation.
Request takes a JSON Identifier (with Output Parameters) of the Job Set ID as content, and on success returns a response containing additional headers that specify the ID of the new operation as well as link URLs that can be used to retrieve further information/cancel the operation.
Request
Method Type: |
POST |
URI: | |
Content: | JSON Identifier (with Output Parameters) specifying the Job Set entity's ID |
Content Type: |
application/json |
Add. Headers: |
Parameters
Path
configId |
The Managed File ID (or Name) of the Output Creation Preset in File Store |
Response
Success
202 Accepted |
Error
401 Unauthorized |
application/json |
403 Forbidden |
application/json |
404 Not Found |
application/json |
Output Creation Preset or Job Set entity not found in File Store/Server |
500 |
application/json |
JSON Identifier invalid or missing required structure |
