Run +PReS Enhance Workflow Configuration
Submits a request to run a +PReS Enhance workflow configuration via the Weaver engine directly, using a list of command-line arguments.
Request takes no content, and on success returns a response containing the result of the request to run/execute the workflow configuration.
Request
Method Type: |
GET |
URI: |
/rest/serverengine/workflow/outputcreation/execute/{args}/{size} |
Content: | – |
Content Type: |
Add. Headers: |
Parameters
Path
args |
A comma delimited, URI encoded list of command-line arguments to use to execute the Weaver engine including1:
size |
The estimated page size, used by OL Connect to determine the job size (which determines the number of speed units to use) |
1 For a list of all the available command-line arguments accepted by the Weaver engine, please reference the +PReS Enhance documentation.
Response
Success
200 OK |
Result of request to run +PReS Enhance workflow | text/plain | – | +PReS Enhance Workflow Configuration successfully run/executed |
Error
401 Unauthorized |
application/json |
403 Forbidden |
application/json |
