Display of Working Example Results
When a working example is run, any results will be displayed in a Results area that will appear below the working example existing HTML interface.
For example:
Note: In some examples the same result will displayed in both plain and JSON structure based formats. This is to assist ease-of-use when working with outputs of one example that will be needed as an input to another example.
A working example can be run multiple times, and each time the results will be appended below allowing you to compare the output of varying inputs. The Clear button can be selected at any time to clear all existing results.
