Using the Working Examples with Server Security
If you have the Server Security Settings set to enabled in your OL Connect Server Preferences, then you may see the following dialog box initially display when working with the examples:
In the event of this dialog box, just follow the instructions and either refresh the page or re-authenticate by running the Authenticating with the Server (Authenticate/Login to Server) working example covered under the Server Security & Authentication section.
Note: Once re-authenticated, you shouldn’t see this dialog box again for as long as your session remains active.
