Authenticating with the Server
Problem
Your OL Connect Server is configured to use server security, and you want to authenticate with the server to obtain the correct access to make future requests.
Solution
The solution is to create a request using the following URI and method type to authenticate with the server via the Authentication REST service:
Authenticate/Login to Server | /rest/serverengine/authentication/login | POST |
Example
HTML5
auth-login-server.html
<!DOCTYPE html>
<html>
<head>
<meta charset="utf-8">
<title>Authenticate/Login to Server Example</title>
<script src="js/auth-login-server.js"></script>
</head>
<body>
<h2>Authentication Service - Authenticate/Login to Server Example</h2>
<form>
<fieldset>
<legend>Inputs</legend>
<div>
<label for="username">Username:</label>
<input id="username" type="text" placeholder="Username" required>
</div>
<div>
<label for="password">Password:</label>
<input id="password" type="password" placeholder="Password" required>
</div>
</fieldset>
<fieldset>
<legend>Actions</legend>
<div>
</div>
</fieldset>
</form>
</body>
</html>
JavaScript/jQuery
/* Authentication Service - Authenticate/Login to Server Example */
(function ($, c) {
"use strict";
$(function () {
c.setupExample();
event.preventDefault();
var username = $("#username").val(),
password = $("#password").val();
$.ajax({
type: "POST",
url: "/rest/serverengine/authentication/login",
beforeSend: function (xhr) {
var base64 = "Basic " + btoa(username + ":" + password);
xhr.setRequestHeader("Authorization", base64);
.done(function (response) {
c.displayStatus("User '" + username + "' Authenticated Successfully");
c.displayResult("Authorization Token", response);
c.setSessionToken(response);
.fail(function (xhr, status, error) {
c.displayStatus("Authentication of User '" + username + "' failed!");
c.displayResult("Status", xhr.status + " " + error);
c.displayResult("Error", xhr.responseText);
c.setSessionToken(null);
}(jQuery, Common));
Screenshot & Output
Usage
To run the example simply enter your credentials into the Username and Password fields and select the Submit button.
Once selected, a request containing the credentials will be sent to the server and the result will be returned and displayed to the Results area.
If authentication was successful then the response will contain an Authorization Token that can be then used in the submission of future requests to the server.
Discussion
When our event hander function is called, we then obtain the value of the Username and Password fields. We define two variables, username
to hold the value of the Username text field and password
to hold the value of the Password text field.
Next we construct an jQuery AJAX request which will be sent to the Authentication REST service:
Method type
and url
arguments are specified as shown earlier.
We specify a beforeSend
argument containing a function that will add an additional Authorization
header to the request to facilitate Basic HTTP Authentication. The value of the Authorization
request header is a Base64 digest of the username
and password
variables.
When the request is successful or done, a request response is received and the content of that response is passed as the function parameter response
. In the example, we then display the value of this parameter which should be the new Authorization Token which can then be used in the submission of future requests to the server.
This is achieved by placing the value of the Authorization Token in the auth_token
request header of a future request. In the example the common function setSessionToken
is used to facilitate this function for all future working example requests.
Further Reading
See the Authentication Service page of the REST API Reference section for further detail.
