Running a Content Creation Operation for Print By Data Set
Problem
You want to run a content creation operation to produce a Content Set using a template and an existing set of Data Records as inputs.
Solution
The solution is to make a series of requests using the following URIs and method types to submit, monitor progress and ultimately retrieve the result of the content creation operation. There is also the option of cancelling an operation during processing if required. These requests can be submitted via the Content Creation REST service:
Process Content Creation | /rest/serverengine/workflow/contentcreation/{templateId}/{dataSetId} | POST |
Get Progress of Operation | /rest/serverengine/workflow/contentcreation/getProgress/{operationId} | GET |
Get Result of Operation | /rest/serverengine/workflow/contentcreation/getResult/{operationId} | POST |
Cancel an Operation | /rest/serverengine/workflow/contentcreation/cancel/{operationId} | POST |
Example
HTML5
cc-process-by-dse.html
<!DOCTYPE html>
<html>
<head>
<meta charset="utf-8">
<title>Process Content Creation (By Data Set) Example</title>
<script src="js/cc-process-by-dse.js"></script>
</head>
<body>
<h2>Content Creation Service - Process Content Creation (By Data Set) Example</h2>
<form>
<fieldset>
<legend>Inputs</legend>
<div>
<label for="dataset">Data Set ID:</label>
<input id="dataset" type="text" placeholder="1234" required>
</div>
<div>
</div>
</fieldset>
<fieldset>
<div>
</div>
<div>
</div>
</fieldset>
</form>
</body>
</html>
JavaScript/jQuery
/* Content Creation Service - Process Content Creation (By Data Set) Example */
(function ($, c) {
"use strict";
$(function () {
c.setupExample();
$cancelButton = $("#cancel"),
$progressBar = $("progress"),
operationId = null;
if (operationId !== null) {
/* Cancel an Operation */
$.ajax({
type: "POST",
url: "/rest/serverengine/workflow/contentcreation/cancel/" + operationId
.done(function (response) {
operationId = null;
setTimeout(function () {
}, 100);
event.preventDefault();
var dataSetId = $("#dataset").val(),
templateId = $("#template").val();
/* Get Result of Operation */
$.ajax({
type: "POST",
url: "/rest/serverengine/workflow/contentcreation/getResult/" + operationId
c.displaySubResult("Content Set IDs", response);
/* Process Content Creation (By Data Set) */
$.ajax({
type: "POST",
url: "/rest/serverengine/workflow/contentcreation/" + templateId + "/" + dataSetId
var progress = null;
c.displayStatus("Content Creation Operation Successfully Submitted");
$.ajax({
type: "GET",
cache: false,
url: "/rest/serverengine/workflow/contentcreation/getProgress/" + operationId
if (response !== "done") {
if (response !== progress) {
progress = response;
} else {
getFinalResult();
operationId = null;
}, 100);
getProgress();
}(jQuery, Common));
Screenshot & Output
Usage
To run the example simply enter the Data Set ID and the Managed File ID or Name of your template (previously uploaded to the file store) into the appropriate text fields, and then select the Submit button to start the content creation operation.
The progress of the operation will be displayed in the progress bar, and once the content creation operation has completed, the IDs of the Content Sets created will be returned and displayed to the Results area.
Further Reading
See the Content Creation Service page of the REST API Reference section for further detail.
