Running a Data Mapping Operation for PDF/VT File (to Content Set)
Problem
You want to run a data mapping operation to produce a Content Set using only a PDF/VT file as input.
Solution
The solution is to make a series of requests using the following URIs and method types to submit, monitor progress and ultimately retrieve the result of the data mapping operation. There is also the option of cancelling an operation during processing if required. These requests can be submitted via the Data Mapping REST service:
Process Data Mapping (PDF/VT to Content Set) /rest/serverengine/workflow/datamining/pdfvtcs/{dataFileId} POST
Get Progress of Operation /rest/serverengine/workflow/datamining/getProgress/{operationId} GET
Get Result of Operation /rest/serverengine/workflow/datamining/getResult/{operationId} POST
Cancel an Operation /rest/serverengine/workflow/datamining/cancel/{operationId} POST
Example
HTML5
dm-process-pdfvt-cse.html
Copy
<!DOCTYPE html>
<html>
    <head>
        <meta charset="utf-8">
        <title>Process Data Mapping (PDF/VT to Content Set) Example</title>
        <script src="js/dm-process-pdfvt-cse.js"></script>
    </head>
    <body>
        <h2>Data Mapping Service - Process Data Mapping (PDF/VT to Content Set) Example</h2>
        <form>
            <fieldset>
                <legend>Inputs</legend>
                <div>
                    <label for="datafile">Data File ID/Name:</label>
                    <input id="datafile" type="text" placeholder="1234 or Filename" required>
                </div>
            </fieldset>
            <fieldset>
                <legend>Progress &amp; Actions</legend>
                <div>
                </div>
                <div>
                </div>
            </fieldset>
        </form>
    </body>
</html>
JavaScript/jQuery
Copy
/* Data Mapping Service - Process Data Mapping (PDF/VT to Content Set) Example */
(function ($, c) {
    "use strict";
    $(function () {
        c.setupExample();
            $cancelButton = $("#cancel"),
            $progressBar = $("progress"),
            operationId = null;
            if (operationId !== null) {
                /* Cancel an Operation */
                $.ajax({
                    type:   "POST",
                    url:    "/rest/serverengine/workflow/datamining/cancel/" + operationId
                    .done(function (response) {
                        operationId = null;
                        setTimeout(function () {
                        }, 100);
            event.preventDefault();
            var dataFileId = $("#datafile").val();
                /* Get Result of Operation */
                $.ajax({
                    type:   "POST",
                    url:    "/rest/serverengine/workflow/datamining/getResult/" + operationId
                        c.displaySubResult("Content Set ID", response);
            /* Process Data Mapping (PDF/VT to Content Set) */
            $.ajax({
                type:   "POST",
                url:    "/rest/serverengine/workflow/datamining/pdfvtcs/" + dataFileId
                    var progress = null;
                    c.displayStatus("Data Mapping Operation Successfully Submitted");
                            $.ajax({
                                type:   "GET",
                                cache:  false,
                                url:    "/rest/serverengine/workflow/datamining/getProgress/" + operationId
                                    if (response !== "done") {
                                        if (response !== progress) {
                                            progress = response;
                                    } else {
                                        getFinalResult();
                                        operationId = null;
                                        }, 100);
                    getProgress();
}(jQuery, Common));
Screenshot & Output
Usage
To run the example simply enter the Managed File ID or Name for your PDF/VT file (previously uploaded to the file store) into the appropriate text field, and then select the Submit button to start the data mapping operation.
The progress of the operation will be displayed in the progress bar, and once the data mapping operation has completed, the ID of the Content Set created will be returned and displayed to the Results area.
Further Reading
See the Data Mapping Service page of the REST API Reference section for further detail.
