Running a Job Creation Operation By Content Set with Runtime Parameters (Using JSON)
Problem
You want to run a job creation operation to produce a Job Set using a job creation preset, an existing set of Content Sets and runtime parameters as inputs.
Solution
The solution is to make a series of requests using the following URIs and method types to submit, monitor progress and ultimately retrieve the result of the job creation operation. There is also the option of cancelling an operation during processing if required. These requests can be submitted via the Job Creation REST service:
Process Job Creation (By Content Set) (Runtime Parameters) (JSON) | /rest/serverengine/workflow/jobcreation/{configId} | POST |
Get Progress of Operation | /rest/serverengine/workflow/jobcreation/getProgress/{operationId} | GET |
Get Result of Operation | /rest/serverengine/workflow/jobcreation/getResult/{operationId} | POST |
Cancel an Operation | /rest/serverengine/workflow/jobcreation/cancel/{operationId} | POST |
Example
HTML5
jc-process-by-cse-params-json.html
<!DOCTYPE html>
<html>
<head>
<meta charset="utf-8">
<title>Process Job Creation (By Content Set) (Runtime Parameters) (JSON) Example</title>
<script src="js/jc-process-by-cse-params-json.js"></script>
</head>
<body>
<h2>Job Creation Service - Process Job Creation (By Content Set) (Runtime Parameters) (JSON) Example</h2>
<form>
<fieldset>
<legend>Inputs</legend>
<div>
<label for="contentsets">Content Set ID(s):</label>
<input id="contentsets" type="text" placeholder="1234, 2345, 3456, ..." required>
</div>
<div>
<label for="jcpreset">Job Creation Preset ID/Name:</label>
<input id="jcpreset" type="text" placeholder="1234 or Filename" required>
</div>
<div>
<label for="parameters">Runtime Parameters:</label>
<table id="parameters" class="name-value parameters">
<tbody>
<tr>
<th></th>
<th>Name</th>
<th>Type</th>
<th>Value</th>
</tr>
<tr class="placeholder" hidden>
<td></td>
<td>
<input type="text" disabled>
</td>
<td>
<select disabled>
<option value="string">String</option>
</select>
</td>
<td>
</td>
</tr>
</tbody>
</table>
</div>
<div>
<input class="remove-parameter" type="button" value="Remove Selected" disabled>
<input class="add-parameter" type="button" value="Add Parameter">
</div>
</fieldset>
<fieldset>
<div>
</div>
<div>
</div>
</fieldset>
</form>
</body>
</html>
markup.html
<!-- OL Connect REST API Cookbook - Working Examples [Markup HTML Snippet] -->
<div id="input-name-type-value-pair-row">
<table>
<tr class="root">
<td>
<input class="use-option" type="checkbox">
</td>
<td class="name">
<input type="text" placeholder="Name" required>
</td>
<td class="type">
<select id="type" class="options-selector">
<option value="number">Number</option>
<option value="boolean">Boolean</option>
<option value="date">Date</option>
</select>
</td>
<td class="option type-string value">
<input type="text" placeholder="Value" required>
</td>
<td class="option type-number value">
<input type="number" step="0.001" placeholder="Value" required />
</td>
<td class="option type-boolean value">
<input type="checkbox" />
</td>
<td class="option type-date value">
<input id="value1" type="date" required />
</td>
</tr>
</table>
</div>
JavaScript/jQuery
/* Job Creation Service - Process Job Creation (By Content Set) (Runtime Parameters) (JSON) Example */
(function ($, c) {
"use strict";
$(function () {
c.setupExample();
var $parameters = $("#parameters"),
$submitButton = $("#submit"),
$cancelButton = $("#cancel"),
$progressBar = $("progress"),
operationId = null;
c.setupRuntimeParametersTableInput($parameters);
if (operationId !== null) {
/* Cancel an Operation */
$.ajax({
type: "POST",
url: "/rest/serverengine/workflow/jobcreation/cancel/" + operationId
.done(function (response) {
operationId = null;
setTimeout(function () {
}, 100);
event.preventDefault();
var contentSetIds = $("#contentsets").val(),
configId = $("#jcpreset").val();
/* Get Result of Operation */
$.ajax({
type: "POST",
url: "/rest/serverengine/workflow/jobcreation/getResult/" + operationId
c.displaySubResult("Job Set ID", response);
/* Construct JSON Identifier List (with Runtime Parameters) */
var jsonConfig = c.plainIDListToJson(contentSetIds),
jsonParameters = c.tableToJsonRuntimeParameters($parameters);
if (Object.keys(jsonParameters.parameters).length)
jsonConfig.parameters = jsonParameters.parameters;
/* Process Job Creation (By Content Set) (Runtime Parameters) (JSON) */
$.ajax({
type: "POST",
url: "/rest/serverengine/workflow/jobcreation/" + configId,
data: JSON.stringify(jsonConfig),
contentType: "application/json"
var progress = null;
c.displayStatus("Job Creation Operation Successfully Submitted");
// Get Progress of Operation
$.ajax({
type: "GET",
cache: false,
url: "/rest/serverengine/workflow/jobcreation/getProgress/" + operationId
if (response !== "done") {
if (response !== progress) {
progress = response;
} else {
getFinalResult();
operationId = null;
}, 100);
getProgress();
}(jQuery, Common));
Screenshot & Output
Usage
To run the example simply enter a comma delimited list of your Content Set IDs and the Managed File ID/Name of your job creation preset (previously uploaded to the file store) into the appropriate text fields.
Next, specify one or more Runtime Parameters. Parameters can be added and removed using the Add Parameter and Remove Selected buttons respectively, and once added the following fields can be then populated for each parameter:
Name – The name of the runtime parameter (as specified in the Job Creation Preset)
Type – The type of the runtime parameter as either String, Number, Boolean or Date (as specified in the Job Creation Preset)
Value – The value of the runtime parameter (specific to the type selected)
Lastly, select the Submit button to start the job creation operation.
The progress of the operation will be displayed in the progress bar, and once the job creation operation has completed, the ID of the Job Set created will be returned and displayed to the Results area.
Further Reading
See the Job Creation Service page of the REST API Reference section for further detail.
