Process All-In-One (Adhoc Data)
Submits a request to initiate a new All-In-One operation using pre-existing inputs, with the exception of input data, which is submitting along with the request.
Request takes binary file data as content, and on success will return one of two responses depending on the type of operation:
- Asynchronous – response containing additional headers that specify the ID of the new operation as well as link URLs that can be used to retrieve further information/cancel the operation (Default)
- Synchronous – response (depending on the parameters specified) containing either:
- the absolute paths of the final output files produced (multiple spool files) or the content of a final output file (single spool file)
- the absolute path or paths of the final output file or files produced (single or multiple spool files respectively) (Get Result as Text Only)
Request
Method Type: |
POST |
URI: |
/rest/serverengine/workflow/print/{dmConfigId}/{templateId}/{jcConfigId}/{ocConfigId} |
Content: | Data File (File) |
Content Type: |
application/octet-stream |
Add. Headers: |
Parameters
Path
dmConfigId |
The Managed File ID (or Name) of the Data Mapping configuration in File Store |
templateId |
The Managed File ID (or Name) of the template in File Store |
jcConfigId |
Optional – the value of "0" can be specified if no preset is to be used |
The Managed File ID (or Name) of the Job Creation Preset in File Store |
ocConfigId |
The Managed File ID (or Name) of the Output Creation Preset in File Store |
Query
async | – | – |
true |
Whether to run the operation asynchronously |
resultAsTxt |
false |
createOnly |
false |
Whether output is to be only created in the server and not sent to it's final destination |
printRange |
A specific range of records in the input data file to restrict the print output to |
filename |
The file name of the data file to be uploaded |
jobOutputFolder | - | String | - | The job output folder to use during output creation |
Response
Success
202 Accepted |
Data file successfully uploaded to File Store and creation of new operation successful |
Success (Synchronous)
200 OK |
Absolute Paths of the Output Files or the Output File itself | application/octet-stream | – | Data file uploaded to File Store and a new operation was created and completed successfully with the result returned |
Success (Synchronous + Get Result as Text)
200 OK |
Absolute Path(s) of the Output File(s) | text/plain | – | Data file uploaded to File Store and a new operation was created and completed successfully with the result returned |
Error
400 Bad Request |
application/json | – |
Unable to locate one or more inputs in File Store with Managed File ID(s) and/or Name(s) specified, or the job output folder specified is not valid. |
401 Unauthorized |
application/json |
403 Forbidden |
application/json |
500 Internal Server Error |
General error with running the All-In-One Process or a specific error relating to the uploading of the data file or an individual workflow process (see error description) |
