Authenticate/Login to Server
Submits an authentication request (using credentials) to the Connect server and if successful provides access to the various other REST API services available.
Request takes no content, but requires an additional Authorization header which contains a base64 encoded set of credentials (username and password). On success, the response will return an authorization token which can then be used as an additional auth_token header in any future requests made to the REST API services.
Request
| Method Type: |
POST |
| URI: | |
| Content: | – |
| Content Type: |
| Add. Headers: |
Authorization – Basic Authentication (Username and Password) credentials (Base64 encoded) |
Response
Success
| 200 OK |
Authorization Token | text/plain | Token-Expires-In - The number of seconds the token is valid | Server authentication successful, new authorization token generated. |
Error
401 Unauthorized |
application/json |
