Cancel an Operation
Requests the cancellation of a running Content Creation operation of a specific operation ID.
Request takes no content, and on success returns a response with no content.
Request
Method Type:
POST
URI:
/rest/serverengine/workflow/contentcreation/cancel/{operationId}
Content: –
Content Type:
Add. Headers:
Parameters
Path parameters
operationId
Operation ID of Content Creation operation
Response
Success
204
No Content
Operation cancellation requested
Error
401 Unauthorized
application/json
Response when either:
403 Forbidden
application/json
404 Not Found
application/json
Operation not found in Server
