Upload Template
Submits a template to the File Store.
Request takes zipped file data as content, and on success returns a response containing the new Managed File ID for the template.
Request
Method Type:
POST
URI:
/rest/serverengine/filestore/template
Content: Template (File)
Content Type:
application/zip
Add. Headers:
Parameters
Query
filename – – –
The file name of the template to be uploaded
persistent
false
Whether the template to be uploaded will be persistent in File Store
Response
Success
200
OK
Managed File ID (or Name) text/plain – Template successfully uploaded to File Store
Error
400
Bad Request
application/json
Request contains no data for upload to File Store.
401 Unauthorized
application/json
Response when either:
403 Forbidden
application/json
