Get Job Properties
Returns a list of the properties for a specific Job entity.
Request takes no content, and on success returns a response containing a JSON Name/Value List (Properties Only) of all the properties for the Job.
Request
Method Type:
GET
URI:
/rest/serverengine/entity/jobs/{jobId}/properties
Content: –
Content Type:
Add. Headers:
Parameters
Path
jobId
The ID of the Job entity in Server
Response
Success
200
OK
JSON Name/Value List (Properties Only) of properties for Job application/json – Job entity properties successfully retrieved
Error
401 Unauthorized
application/json
Response when either:
403 Forbidden
application/json
