Process Data Mapping
Submits a request to initiate a new Data Mapping operation.
Request takes an optional JSON Data Mapping Parameters, and on success returns a response containing additional headers that specify the ID of the new operation as well as link URLs that can be used to retrieve further information/cancel the operation.
Request
| Method Type: |
POST |
| URI: |
/rest/serverengine/workflow/datamining/{configId}/{dataFileId} |
| Content: |
(Optional) JSON Data Mapping Parameters |
| Content Type: |
application/json |
| Add. Headers: |
Parameters
Path
| Name | Required | Type | Default Value | Description |
configId |
The Managed File ID (or Name) of the Data Mapping configuration in File Store |
| dataFileId | – | – | – |
The Managed File ID (or Name) of the PDF/VT data file in File Store |
Query
| validate | – | – |
false |
Only validate the Data Mapping operation to check for mapping errors |
Response
Success
| 202 Accepted |
Error
400 |
application/json | – |
Data file or Data Mapping Configuration not found in File Store |
401 Unauthorized |
application/json |
403 Forbidden |
application/json |
Error (Validate)
401 Unauthorized |
application/json |
403 Forbidden |
application/json |
500 |
