Process Content Creation (By Data) (JSON)
Submits a request to initiate a new Content Creation operation.
Request takes a JSON Record Data List of the data values for one or more Data Records as content, and on success returns a response containing additional headers that specify the ID of the new operation as well as link URLs that can be used to retrieve further information/cancel the operation.
Request
Method Type:
POST
URI:
/rest/serverengine/workflow/contentcreation/{templateId}
Content: JSON Record Data List specifying a list of data values for the Data Record(s)
Content Type:
application/json
Add. Headers:
Parameters
Path
templateId
The Managed File ID (or Name) of the template in File Store
Response
Success
202
Accepted
  • operationId – Operation ID of new Content Creation operation
Error
401 Unauthorized
application/json
Response when either:
403 Forbidden
application/json
404 Not Found
application/json
Template not found in File Store
