Feature Mapping
This page provides an overview on how Workflow features/techniques map to their Node-RED equivelant. Some tasks can be mapped to standard features in Node-RED where others require third party nodes (for now) or are handled by Node-RED specific techniques.
Inputs
Workflow plug-in Node-RED node Node Type Note
Node JS Server Input http in, http response
STANDARD NODE-RED
Folder Capture folder capture OL FILES AND FOLDERS
Folder Listing folder listing
LPD Input   No alternative yet Planned for OL Connect 2026.2.
Create File inject STANDARD NODE-RED
Email/SMTP Input node-red-node-email STANDARD NODE-RED Needs to be installed separately.
FTP/SFTP/FTPS Input ftp client OL FTP PACKAGE Use the List directory operation.
Telnet Input tcp in, tcp out
STANDARD NODE-RED
Input SOAP node-red-contrib-soap THIRD PARTY
Merge PDF Files
WinQueue Input   WORK IN PROGRESS Planned for OL Connect 2026.1 and OL Connect Automate 1.1.
Secure Email Input node-red-node-email STANDARD NODE-RED Needs to be installed separately.
Begin Sub Use Node-RED subflows or links STANDARD NODE-RED
InputErrorBin catch STANDARD NODE-RED
Serial Input
O365 Email Input   OL M365 PACKAGE
O365 One Drive   OL M365 PACKAGE
Actions
Add/Remove Text
Advanced Search and Replace
change
STANDARD NODE-RED
Barcode Scan
    Planned for OL Connect 2026.1, as a Document Boundaries option and extraction through scripting in DataMapper.
Change Emulation
Create PDF
ps to pdf
OL CONNECT PACKAGE
In preparation for a new node supporting PDF operations, a PS to PDF endpoint has been added to OL Connect Server 2025.2.
Database Query
node-red-node-mysql
(handles both MySQL and MariaDB)
THIRD PARTY
A sample scenario on integrating an external database is outlined in Use External Databases.
node-red-node-sqlite
THIRD PARTY
See above
node-red-contrib-mssql-plus
THIRD PARTY
See above
Decompress file(s)
node-red-contrib-zip
THIRD PARTY
Create and read ZIP files.
Digital Action
External Program
exec
STANDARD NODE-RED
HTTP Client Input
http request
STANDARD NODE-RED
Load External File
read file
STANDARD NODE-RED
Logger
debug
STANDARD NODE-RED
Mathematical Operations
jsonata in change or script in function nodes
STANDARD NODE-RED
Open XSLT
THIRD PARTY
PDF/A-3 Attachments
    Planned for OL Connect 2026.2 as a native feature in OL Connect.
Push to Repository
use third-party database integration nodes
THIRD PARTY
Use alternative database, for example a custom schema in Maria DB, as described in Use External Databases.
Rename
file operations (move) OL FILES AND FOLDERS
Run Script
function
STANDARD NODE-RED
Search and Replace
change
STANDARD NODE-RED
Send to Folder
Set Job Infos and Variables
change
STANDARD NODE-RED
SOAP Client
Standard Filter
Translator
XML/JSON Conversion
xml
STANDARD NODE-RED
OL Connect
Create Print Content
paginated content
OL CONNECT PACKAGE
Create Job
paginated job
OL CONNECT PACKAGE
Create Output
paginated output
OL CONNECT PACKAGE
Create Email Content
Render Email Content
email content
OL CONNECT PACKAGE
Download EML
OL CONNECT PACKAGE
Use file store download.
Create Web Content
html content
OL CONNECT PACKAGE
Execute Data Mapping
data mapping
OL CONNECT PACKAGE
Separate nodes, previously integrated in Execute Data Mapping for Workflow.
data get
OL CONNECT PACKAGE
Update Data Records
data update
OL CONNECT PACKAGE
Set Properties
set properties
OL CONNECT PACKAGE
Retrieve Items
query items
OL CONNECT PACKAGE
All in One
all in one
OL CONNECT PACKAGE
File Store - Delete File
file delete
OL CONNECT PACKAGE
File Store - Download File
file download
OL CONNECT PACKAGE
File Store - Upload File
file upload
OL CONNECT PACKAGE
Create Preview PDF
preview pdf
OL CONNECT PACKAGE
preview image
  Generates a rasterized image of a template (print/web/email).
Mark Content Sets for Deletion
OL CONNECT PACKAGE
Create PDF/VT
Merge Jobs
Process Logic
Branch
Use wires to branch out
STANDARD NODE-RED
Comment
comment
STANDARD NODE-RED
File Count
File Name Condition
switch
STANDARD NODE-RED
File Size Condition
switch
STANDARD NODE-RED
File/Folder Condition
Go Sub
Sub flows
STANDARD NODE-RED
Loop
Run Script
function
STANDARD NODE-RED
Send to Process
link, complete
STANDARD NODE-RED
SNMP Condition
Text Condition
switch
STANDARD NODE-RED
Time of Day Condition
Send to Folder
write file / send to folder
STANDARD NODE-RED
OL CONNECT PACKAGE
Available through various techniques. OL Connect nodes like all-in-one and paginated output allow for direct output to folder as zip or individual files.
Delete
file operations
End subprocess
This is an output anchor of an subflow.
FTP Output
ftp client
OL FTP Package
Use the Put operation.
SFTP/FTPS
ftp client
OL FTP Package
M365 Email
olm365 email
OL M365 Package
M365 OneDrive
olm365 one drive
OL M365 Package
Print using a Windows printer
Printer Queue Output
Secure Email Output
node-red-node-email
STANDARD NODE-RED
Send Email
node-red-node-email
STANDARD NODE-RED
SOAP Client
node-red-contrib-simple-soap
THIRD PARTY
Not validated by OL.
Data splitters
Data splitters
split, join
STANDARD NODE-RED
Convert data to JavaScript objects first.
PDF Splitter
Use a data mapping configuration.
OL Connect Workflow Concepts
Topic Node-RED Node Type Note
Send Configuration Deploy Option STANDARD NODE-RED
On Error Tab catch node STANDARD NODE-RED
Select a sample data file inject STANDARD NODE-RED For more information, see Sample data tactics for Folder Capture in OL Connect Automate.
Startup Process (part 1) inject with schedule STANDARD NODE-RED
Startup Process to prepopulate variables Use Environment Variables instead of loading a JSON/XML/INI file. Environment variables are read before the engine starts; a startup flow my have a slight delay.
Metadata Work with the JavaScript objects in the msg object. STANDARD NODE-RED
